Hello Arthur,
your B & S Sax was made in March 1983.
Best wishes from Sax(ony)
kossten
Beitrag von kossten »
Hello!
Could You please date my B&S tenor sax? The serial number is 4427.
Hello,
There are two tenor-models of B&S "Blue Label". This miracle can just be solved by getting some pictures.
Please a clear photo from the right side. And one from the thumb rest.
Thanks,
kossten
Like these?
Yes, this is enough. Thank you.
Your Tenor is from the first B&S model line.
#4427 was built in 1977.
Regards, Tobi.
kossten
Could You please name the key differences between two models if it is not too much trouble?
Ok - the following was said by B&S:
Optimization of tonal parameters such as tuning, response, intonation and improvement of the fingering. On the tenor, changes were made to the scale (Mensur) in order to achieve an optimum sound radiation. I.e. a modification of bell diameter and angle. In addition, the tone holes were changed in size and position to ensure first-class tuning. Furthermore, a different bow and an optimization of the grip sections.
By the way - all this was done in order to even improve a horn, which was already excellent! In reality, the result was there, but it was definitely not a big step forward. Is there any other comment from anybody, who owns both model lines with the same plating / configuration?
... you are welcome ...
kossten
Thanks a lot!
I wish i knew which model is mine, the "already excellent" or the betterish one... But whatever it is, it sounds like a win for me.
Your Tenor is from first model line. In 1984 / 1985 the second B&S model line started with the a.m. improvements.
Regards, Tobi
deminiliya
Beitrag von deminiliya »
Здравствуйте. Достался очень убитый тенор B&S 2175 Пытаюсь отреставрировать.
Подскажите дату производства, особенности модели и правильный зазор между клапанами и колодцами
Oto.lopez
Beitrag von Oto.lopez »
Hi
I have a tenor sax B&S bluelabel and I need someone information about it. The serial number is not clear, it is like 4335 or 4835. Can you help me please ?
I send a picture of the serial number and the logo
Hi Oto,
I would guess that it is 4335. No real doubt.
If so, it was built in 1975 - first design phase.
Regards,
Tobi
Oto.lopez
Thanks , I am so happy whit the information
Springy
Beitrag von Springy »
Greetings, Mario,
Could you please let me know when the B&S tenor sax, serial No. 1192 was made?
Your help is much appreciated.
Thanks in advance!
Arpad
Hello,
upfront, we need to make sure which model it is.
Photos should clear this up.
Regards, Tobi.
